tropical36
Jun 07, 2018Explorer II
DwnSth wrote:
It sounds like your looking for something older than 5 years. One thing to watch on the Berkshires is on some models pre-2014 they had a recall on over weighted chassis. There was a fix to upgrade the tires and air bags not sure what else. I'd research and verify that. Also, many of the older units came with either the 340hp or 360hp as an option. 340 paired with 2500 transmission while the 360 was paired with a 3100. If you plan to tow more than 5K then keep that in mind. We're new to our 2014 but so far it seems to be in above average shape for a unit it's age. I have the 340hp and it handles our Jeep Wrangler with no problem. Have not had it in mountains yet but will in a few weeks - first big test and will determine if my quest for a diesel pusher was worth it.
If you seem to be lacking in the mountains somewhat, it can hardly be blamed on it being a DP, since you are a little under powered there.
General rule of thumb is 10HP/foot, which usually equates to weight, as well. Even with the Allison being a 2500, it should be OK for a 5K tow on the steepest of grades in the heat of the day and not everyone, wants to be king of the mountain, anyway.
38,780 PostsLatest Activity: Aug 05, 2026
