cajundrag, congratulation on your 35SC. I think you will be happy with your choice. One thing you might want to check out while you are still at this stage is your parking situation. Their tow hitch design is very low to the ground. I had to have a local welder modify mine to raise it 4"-5". I also had to have the ramp into my RV garage redone to keep the fuel tank strap bolts from dragging even after cutting off the excess threads. With these mods, I can now get in and out of the garage without putting boards under the tires.
I noticed on the Motorhome magazine review specs said that the chassis has rear air suspension. I think that is a mistake, at least mine doesn't.
