SkipgExplorer IIFeb 28, 2015Nitrogen in tiresI have been told by our local tire dealer that since nitrogen is an inert gas you not will have the fluctuation in psi when tires warm up. How true is this statement? Thanks for your input. SkipShow More
wolfe10ExplorerFeb 28, 2015Skip,Bottom line-- you met a tire dealer who failed high school chemistry!The Ideal Gas Law tops all advertising claims.However, there are actually THREE types of gasses that are used in tires:1. Nitrogen.2. DRY air (like with a good compressor and quality air dryer)3."Regular" air with moisture (like in those coin op air compressors)1 and 2 behave very similarly. Since water is NOT an ideal gas, "regular" air does have more PSI change with temperature change.
Related ContentNitrogen tiresNitrogen Tire Top Off Kitnitrogen filled tiresNitrogen Filled TiresNitrogen in Trailer Tires
