- Pirate1ExplorerP0041 downstream heated exhaust oxygen sensors swapped from bank to bank
- ArchHoaglandExplorer
Pirate wrote:
No active codes. The code is a stored pending.
What code is it? - wa8yxmExplorer IIIJust because FORD says there "Should be" does not mean there is.
Plus the pre-cat sensor can be anywhere from the manifold to the cat. (But I think that's sensor 1) not all vehicles have a sensor 2.
By the way I stress the words I THINK in the prens part. I may be wrong. - Pirate1Explorer
MountainAir05 wrote:
I thought of that however, I looked all over the area and no harness of plugs were near the cat.
if you had to change out the unit that had the 02 install they might not have put it back or could not get it out. Had that happen on a warranty part and they put a plug in till the new part came in. - MountainAir05Explorer IIif you had to change out the unit that had the 02 install they might not have put it back or could not get it out. Had that happen on a warranty part and they put a plug in till the new part came in.
- allbrandautoExplorerwhen was the last time you checked ob2 could have been in there for ever the sensor would be in the back of the cat or the pipe off the cat if you had one
- Pirate1ExplorerNo active codes. The code is a stored pending.
- allbrandautoExplorerdo you a check engine light on with a code for down stream o2 sensor if not you don't have one
38,763 PostsLatest Activity: Dec 05, 2025
