clayk's avatar
clayk
No AC power to appliances... PROBLEM SOLVED
I have no power to the refrigerator, microwave and most outlets when plugged into shore power. My load indicator shows that its plugged in and has 50 amps but nothing will work. It will only run on the coach batteries and will run them down. It will not charge the coach batteries either? They are brand new this was the first trip with them. I've had the rv for 3 years with no problems. This was our second trip out this year worked fine first trip.
Same thing happens when I run on genset power.
2005 fleetwood Discovery 39A inverter/charger is a xantrex freedom 458
I've checked the breakers and GFCI breakers all are good.
Any help would be appreciated.
PROBLEM SOLVED. THERE IS A SMALL FUSE INSIDE THE INVERTER THAT WAS BLOWN. NEW FUSE AND ITS BACK TO WORKING LIKE A CHAMP.... THANKS TO ALL OF YOU.
