raining and wind blowing me away will check and advise later. I cant thank you all enough as this is a learning curve my first MH . Redone the roof and put the extension ladder up against the rear moved it and yep wiped out the ladder. I am 6'4 inch and 300 lbs so I don't like stressing the ladder that came on it..while fixing the roof leaks . It rained hard all night and no leaks... The previous owner fought it also as it appeared he used everything on the planet to fix, got the heat gun and scrappers and took it done to original replace antenna and refrigerator vent and sewer vent, Used the roof tape with aluminum backing, then cool sealed the whole thing. NO LEAKS , now just figure out this wiring issue and replace water filters and we are ready to roll, also new breaks, and oil seals and air bags.. Tired of spending money for awhile ready to enjoy!
