Harvey51
Sep 29, 2019Explorer
Check voltage at the fuses. They should have the same voltage as the battery ( 12.6 volts) from both contacts on the fuse to ground. If not the problem is between the battery and the fuses, including ground wires.
We have a battery disconnect switch at the door on our Adventurer on 2004 E350. It looks the same as the switches for outside and inside ceiling lights. The disconnect switch failed. I managed to fix it - just a poor connection I think. Some RVs have a relay but ours is just a plain switch on a wire from the battery positive to a connection point near the converter and fuses.
38,769 PostsLatest Activity: Mar 31, 2026
