enblethen
Jan 09, 2017Nomad
Large inverters have their own transfer switch.
No inverter power does not go through the transfer switch.
Incoming power from genset and shore power goes through transfer switch, then to a branch breaker that feeds the inverter.
You could have a partially tripped circuit breaker in the 120 power distribution panel.
Is your rig a 30 or 50 ampere shore power?
Start by resetting all citcuit breakers. Turn them all off applying light pressure toward off, then turn main breaker on, if equipped, then each branch breaker one a t a time.
38,769 PostsLatest Activity: Mar 31, 2026
