Kidoo
Jan 09, 2017Explorer
mvpmich wrote:
Definitely the Xfr switch. I had similar problem but switch clicked multiple times when energized then died. You can test the input and output lugs to verify if you are familiar and comfortable with electricity.
Ok, I will check the output on the transfer tomorow, getting late. It is the inverter that flicker when I get the genset running, the transfer switch did flicker once but I do not know if it cliked multiple time as I was on the other side of the MH. I will check that tomorow.
38,769 PostsLatest Activity: Mar 31, 2026
