bdpreece
Jan 10, 2017Explorer II
Shot in the dark here but, You don't by chance have a Xantrex inverter do you? If you do there is a flat plate on the front that has two screws holding it on, inside there are wire nut connectors that work loose over time due to vibration. Almost all AC power goes through the inverter before being distributed to the coach. When mine worked loose some of the wires actually melted .
38,769 PostsLatest Activity: Mar 31, 2026
