Kidoo
Jan 11, 2017Explorer
enblethen wrote:
Yes, that will work. Should be three wires, make sure you have a equipment ground wire to the receptacles.
Make sure you kill 12 volt power to inverter. I would be leary of 12 volt DC power having an issue iside the inverter.
I completely removed the inverter. All I have left are the 3 wires, one from the inverter CB in the panel and 2 going out to the outlets.
What do you mean by making sure I have equipment ground wire to the recepticles?
I am trying to figure out how it is wired in the RV. Does the output wires from the inverter directly goes to the outlets? I suppose they do. I will check these out tomorow.
Thanks.
38,769 PostsLatest Activity: Mar 31, 2026
