dougrainer
Jan 13, 2017Nomad
Kidoo wrote:
The Xantrex is a 2000 watt. Don't know what is the amp charging rate.
They are Smart Chargers. BULK (high) rate is about 100 amps. As the batteries reach full charge the rate(amps) tapers down, until you just need a Maintenance (Float) Charge. Your RV is designed to have a regulated charging system. Your vacation will not be smooth if you try to go a cheap route with your RV 12 volt system. The Converter and
Your Inverter/ Charger are called the HEART of your RV. Without those items working to spec, your RV is useless. Doing a cheap work around will result in a BAD time in Mexico. Doug
38,769 PostsLatest Activity: Mar 31, 2026
