desertslim's avatar
desertslim
No Power To Fuel Pump.
I am puzzled-- Recently had the electric fuel pump replaced ( in the tank type). Drove it home, no problems. Parked in the yard and three weeks later went to start it and it would no fire. I tried starter fluid and it would fire off ok. Checked for fuel at the throttle body inlet, none. Disconnected the connector for the fuel pump at the tank , checked voltage at the three pins. The center one read 8.0 volts. o,o volts on the other two. Had my helper crank the engine while checked the voltage. Same as above. I checked all of the fuses. all ok. This is a 1992 Bounder. All suggestions will be APPRECIATED. Thanks. Jim C
