claywayExplorerApr 08, 2018no power when plugged into 30 ampI have power when on generator but not when plugged into 30 amp.I have a Parallax 7345 converterany thoughts to what to check, I have found no resetsthanks in advance for your help
14 RepliesReplies sorted by NewestShow MoreAvaExplorerApr 08, 2018Possible GFI resetScottGNomadApr 08, 2018The converter has nothing to do with the 120VAC side.2oldmanExplorer IIApr 08, 2018Transfer switch.carringbExplorerApr 08, 2018Make sure you twist the body of the twist lock cord before you twist the retaining ring. That twist lock cord is sensitive to full engagement.
Related Content7 pin plug amperage rating?Shore power plug conversion?Newbie power question12 Volt Power IssueNo Power to 7-Way Plug?
