kansanforlife's avatar
Jul 15, 2013
no propane
Have a 1993 coachmen 30 1 ton chevy chassis. Seems I cant get any propane to any appiances. Having some elec problems. Is there some fuses located some where? Tstove wont even lite. Thanks for any help. I haven't had this very long.
  • donn0128 wrote:
    Do you actually have gas in the tank? Is the valve open? Go back and close the valve, wait about a minute and slowly open the valve, then go tey lighting a stove top burner.
    Because some valves will shut off if opened too quickly (they think there is a major leak or something....)
  • Do you actually have gas in the tank? Is the valve open? Go back and close the valve, wait about a minute and slowly open the valve, then go tey lighting a stove top burner.
  • Check your propane detector along the floor. Some rigs have a solenoid that operates off the LP detector. The solenoid is located adjacent to the LP regulator on the tank. When the LP detector senses LP it shuts off the supply. If the sensor is turned off, there will be no gas flow.
