I got this 2000 REXHALL AERBUS 37' DIESEL MOTORHOME about 5 mth ago and came home set-up checked it out level,water ,power and so on.Was going to start got good battery power but will not turn over. I...
Do you have an alarm system? Some of them have a lock-out and won't allow the engine to start. No ignition at all. Also check the circuit breakers,the 50 amp ones which should be near the battery compartment. On my Tradewinds,there is a 50 amp for the gennie/jacks on the back of the main fuse panel and another one for the starting system near the starting batteries.
