I got this 2000 REXHALL AERBUS 37' DIESEL MOTORHOME about 5 mth ago and came home set-up checked it out level,water ,power and so on.Was going to start got good battery power but will not turn over. I...
If you have two brand new chassis batteries and it is still not cranking up, it has to be something wrong on the starter or solenoid. Tap the starter gently with a small ball pin hammer. Maybe the brushes got hung up. Also check to see if you have power to the starter while someone turns the ignition switch on.
