cwdavis
Aug 24, 2013Explorer
Galvanizd wrote:
Probably need a little more info, but mine did something similar years ago. Electronics. Does this happen when the exhaust brake is on? Happened to me . Turned the exhaust brake off , pushed sharply on the brake and the problem went away. Something do to with the exhaust brake and brake light electronics not releasing properly when you step on the accelerator.
If that works, let me know cause the fix for that is easy and cheap.
We had a similar exhaust brake problem -- had just had a new one installed and experienced a total loss of acceleration whenever it was switched on, after the brake was activated. The temporary fix was switching the brake off! The long term one was replacing the old solenoid on the brake which turned out to be defective.
38,707 PostsLatest Activity: Jan 05, 2014
