- Jay58ExplorerMy minimal problem is it is in a 2020 class a
- chuckftboyExplorerShy of replacement furniture, probably not much you can do.
- 352Explorer IIYour kidding right? I wish everyone out there had these minimal issues. Put on some axel grease where it squeaks.
- Jay58ExplorerWhen reclining or sitting up it is the fabric rubbing...what can be done to silence the rub...its not the frame mechanism
- DrewEExplorer IIIBy "operated", do you mean when reclined or otherwise repositioned, as opposed to simply when someone is squirming while seated?
If so, the noise must be coming from the adjustment mechanism somewhere, and presumably could be eliminated by proper lubrication or adjustment or rebuilding with better bearings/pivots or something along those lines. Personally, I'd just live with it, since fixing seems like it's probably a lot of effort with disassembly and analysis and so forth. - down_homeExplorer II............
- Tom_BarbExplorer IIThey are called Whoopy cushion :)
