MountainAir05
Aug 10, 2019Explorer II
fAN motor bushing needing lube, squirrel cage loose on the shaft. I lube our once a year. Had to replace one right after purchase due to the bushing was dry and worn and made a awful noise. If you do not have a hole where the bushing is , I just drill a small hole and put in the oil that way. We had the same units.
