MountainAir05
Aug 10, 2019Explorer II
From the top. You can see where the bushing on the end case of the motor. If that bad and nothing else found then a new motor. If you can move the motor shaft up/down/sideways, with a lot of play then a new motor will be need. Got mine from PPL. and I drill it before installing and lube it up.
