garymunson's avatar
garymunson
Noisy Workhorse engine fan
Has anyone else been irritated by the thermostatic clutch fan on 8.1 liter Workhorse chassis being very loud? I would like to lessen the times I hear it. I have NEVER seen the gauge climb past 1/2 way and the fan will engage when the gauge is at that point and it is hot outside or I am climbing a long hill. It seems that if the thermostat on the fan was set just a little higher, the fan operation would make much more sense. I would think an engagement at a point just beyond 1/2 way would make more sense. I'd changed to a 180 thermostat (from recommended 195). This had the effect of making normal running temp just shy of the 1/2 mark. With the 195 the gauge would go right to 1/2. As it is now, only on very hot days or hill climbing do I see the 1/2 position, then, at that point, the clutch fan will start engaging frequently and cycling. I have NEVER seen the gauge past 1/2 way and would think it would not be an issue if the engine got a little hotter on a long climb or 100 degree day. Obviously the clutch fan is capable of keeping the engine cool in those conditions so if it would only engage at a slightly higher temp, I would be hearing the fan a lot less. Does anyone have an RV that the gauge WILL go slightly past 1/2 before the fan engages in extreme conditions? I'm wondering if my fan clutch is just mis-calibrated. I also have thought about the new waterless coolants and wonder if they will give me the little edge that will lessen fan engagement. Has anyone tried them? An RV uses quite a bit of coolant and the waterless is quite expensive so I'd sure like to hear about other's experiences before I go that route.
  • I monitor my temperature constantly with my OBDII ScanGauge. My fan clutch locks up when the temperature reaches 207 degrees, which means it very seldom comes on and when it does it is usually in a long climb on a steep highway.
    Analog gauges are notoriously inaccurate and I would suggest that you use a ScanGauge or similar OBDII device to read the ACTUAL temperature that your fan comes on. It may be a bad fan clutch or it may mean that your radiator is not doing it's job.
