JRscooby wrote:
willald wrote:
JRscooby wrote:
willald wrote:
Go to a lumber store, buy you a 2x12 or two, and cut it up into a bunch of squares. Throw a bunch of them in your outside storage.
I'm not real smart. Instead of cutting squares, would it be better to cut different lengths so you can stack short on long, drive up a ramp?
Good point. I should have been more specific about how I cut up the boards.
I actually bolted a total of 3 pieces of 2x12 together, stacked 3 high. Top piece is about 12” long, 2nd piece is about 24” long, and bottom piece is about 3’ long. Provides stair steps to drive up, basically - 3 different steps/levels I can drive the wheels up on, depending on how far off level. I built two of them, carry those as well as a handful of square pieces for the jacks.
I cut some 2X8s with 6 inches different lengths. Then drilled pilot holes thru the stack for alinement. Used 7/8 paddle bit top of half the holes, and 3/8 thru the others. I put carriage bolts thru with nuts and washers. Decide how tall stack, the nuts drop in the large holes to keep boards in line.
Now plastic blocks use similar idea. But I have never seen plastic long enough for a tandem.
Yeah, I quit using the plastic blocks when we got the motorhome. Those plastic one work OK for towable RVs, but don’t trust them to handle the weight of a class A.
Good idea on the carriage bolts. I just screwed all 3 on mine together somewhat permanent, with long wood screws.
