tropical36 wrote:
dougrainer wrote:
tropical36 wrote:
dougrainer wrote:
tropical36 wrote:
Ivylog wrote:
Cooling after tapping on the coils is an indication that you may have a blockage in the cooling unit. Unless it's 50 degrees outside a 1200 needs the fans running to cool properly. How many times do you have to be told to fix your fan problems?
Build/find a platform that is almost as high as the bottom of your 1200. Remove the four screws top and bottom plus probably two at the back through the vent. With someone prying on the bottom from the back and pulling on the front you should be able to slide it out onto the platform. Read my first post and put it back in after fixing the fan problems.
I for one, didn't even know this fridge had fans, but did put one in of my own back there. Could be that mine aren't working either, although it does cool pretty well, if you do everything right, including not loading it with a lot of warm items and turning it up to 9 when it's hot outside.
I did look at the wiring diagrams and yes, it does show two fans. Where they are, pray tell and how they actually provide cooling to the coils in back, I haven't a clue. Also don't hear a thing, if not for my self installed fan, running.
1. the fans are right below the upper condenser
2. 1200 Fans are REQUIRED for the refer to operate correctly
3. How do they provide cooling? Analogy. You have a Radiator on your car. WHY do you need the Fan? To get a good volume of fresh COOL air THRU the radiator fins. Especially when in heavy stop and go traffic and idling. 1200 model refers are HUGE. They require more volume of fresh air from the bottom up thru the top than normal convection air can flow. So, they have 2 fans to pull and push the air thru the Condensor fins and out the top.
4. LACK of adequate air and the refer will not cool correctly. Remove the fan on your Auto. Think it will run cool enough now:B Doug
I get the picture, but are you saying that you have to pull the fridge out for getting to them? Certainly don't see anything from the outside by removing the access panel. The books on the thing, aren't helping much on physical location, either
What kind of symptoms does one have, if these fans that I can't hear, aren't running and other than what the OP is experiencing?
We had a similar Dometic in the old coach that was excellent by comparison to this Norcold and wasn't aware of any fans running with it, either.
Lack 0f adequate cooling. You cannot see the fans. Your Dometic was NOT anyway similar to this model. If you had a Side By Side Dometic, it had 1 rear fan not fans. It also had internal fans. Norcold 1200 models are EXCELLENT in cooling as long as all parameters are to spec. INCLUDING the OEM installation, which lacks on some OEM's and the rv'er blames Norcold instead of the real problem lack of correct installation and baffles by the OEM. Doug
There's a removable panel inside the fridge, with some coils behind it. Would these fans be accessible from this area? Just doesn't seem right, that one can't even see them and they sure must be of the super silent variety, if they're running at all, when required.
OK, now you have me PO'd. I have probably worked on in excess of 500 1200 models in the past 20 years. IF I TELL YOU WHAT MUST BE DONE, DON'T ARGUE. Doug
