tropical36
Aug 24, 2020Explorer II
ferndaleflyer wrote:
OK, back home now and its raining. I had a small 12 volt fan in the garage with an on/off switch and jerry rigged it into the bottom at the back blowing up before we left. It got the freezer below zero and the refrig was 38. Guess that tells me something. When checking it sometimes the cooling coils were cool and other times to hot to touch. There was nothing in the frig at all. What does that tell me?
Well, when the unit is on, it's going to be hot, until it reaches set point and then is going to be off for awhile and will cool down some, depending on ambient, door openings and such, until it calls for cooling again.
I always added extra fans to mine, before the conversion, as well and am glad that those days are over with.
Can't see using an RV fridge these days with adequate batteries and an inverter, no matter how much one might boon dock.
I guess, if one has a roof full of solar power and hates running a genset, that's another story.
Thing is, what would these same people do, having a new rig with a residential? Remove it for an RV replacement type? Don't think I've ever heard of that one, if it exists.
