ron_dittmer
Aug 10, 2015Explorer III
pnichols wrote:Interesting issue and resolution. Good to know if it happens to others.
...I installed spacer washers on the bottoms of the freezer and refrig door hinges for another reason - to make the doors close and latch better. It seemed like there may have been a dimensional problem in the original design, as lifting both doors just a bit with washers on each hinge's shaft at the bottom ends of each shaft made each door's latch mechanism line up better ... and hence close a lot better.
38,768 PostsLatest Activity: Nov 21, 2015
