ron_dittmer
Aug 11, 2015Explorer III
j-d wrote:Those brackets are "AN ADDITION". If you don't see them, then the door hinge is NOT reinforced. Keep in-mind that the hinge most vulnerable to breaking is the lower one on the main door because that is the heaviest door with all the weight resting on that one hinge. As a result, most people add the reinforcement only to that hinge. Look down there, not higher up where I took the pictures. I just did all hinges for my own peace of mind.
....can I determine if it's already been modded? Is the kit a reinforcement or replacement?
38,768 PostsLatest Activity: Nov 21, 2015
