ron_dittmer
Sep 21, 2015Explorer III
j-d wrote:The kit comes with two different brackets to address a right-hand and a left-hand bottom hinge. So j-d, you can use the other piece to reinforce the top hinge on your main (heavy) door.
I wanted to make sure... Is the "Kit" comprised of One Left and One Right Hinge? Let me make sure I understand. If I order one Kit I can reinforce only One Corner of One Door? Or will one Kit reinforce both Top and a Bottom Corners of One Door? It seems that if the Kit is one "Right" and one "Left" reinforcement, then the "Right" would reinforce the TOP hinge of a "Left-Hinged" door.
I'd really like to reinforce the Fridge Door on our N811 at the Lower Left Corner. If I can do the Upper Left Corner with the same Kit, that's wonderful.
No plan to reinforce the Freezer Door.
Again, our Doors are Hinged on the Left Side, same as Ron's pix.
38,767 PostsLatest Activity: Mar 11, 2026
