VintageRacer
Apr 16, 2015Explorer
a bad leveling/ height control valve can cause that to happen. the valve is mounted on the chassis and has a rod connected to the axle. It is supposed to let air into the air springs until the correct height has been reached. If the rod is disconnected the valve will think it's at the correct height and not send air to the suspension.
Brian
Brian
38,773 PostsLatest Activity: Apr 25, 2026
