Octaneforce's avatar
Octaneforce
Explorer II
Sep 29, 2020
Not getting 115v
My 1993 fleetwood coranado class a suddenly will not give me 115v anywhere. When plugged in or even when the generator is running, i have no voltage anywhere. Ive reset all the breakers above the fridge, which are the only 115v breakers im aware of. Im looking for some suggestions on where to start before i start cutting open cabinets.
  • You have to have a curcuit breaker. panel somewhere. Usually they are somewhere near the shore power entey. , never seen one above the fridge. curcuIt panels are always near the power entry into the unit.
    Verify you have 120-240v a/c into the main breaker. Suspect a corroded or failed connection,
    Follow tne power from your " house " to supply with a v/ a meter. A most basic homeowners tool.
    If you have heard of surges. low voltages. Yes they happen in your home as well not only in parks
  • do you have a transfer switch. If so give it a rap with power on and see if it works. You should hear s hum if its working.
    You state no voltage anywhere. Does that mean no light as in 12 volts either. Do you have a switch at the door that turns off all power to the RV. Sometimes call a Salesman switch.
