turbojimmy
Feb 07, 2015Explorer
rv37tonk wrote:
1.)did you remove the fuel line to the filter
2.) place the fuel line in a bucket
3.) push the prime switch to check for fuel flow ?
note: the bottom side of the start switch is the prime switch.
Mine just has a line from the tank to the bottom of the pump. The filter is inside the pump housing. I got a couple-foot long piece of rubber hose, disconnected the feed at the pump and dipped it in a fuel can. I then hit START on the generator. It fired up immediately. This method will test whether the problem is the line from the tank. If the generator still doesn't run, then it could be the filter, the pump itself or something beyond the pump. My electric pump is loud (clicks) and is much louder when there's no fuel. I know when it's running out of gas because it starts to make an awful racket.
38,773 PostsLatest Activity: Apr 24, 2026
