mcal63775
Feb 12, 2015Explorer
After reading other forums with the same issue I have, I replaced the following with OEM parts. Fuel pump, fuel filter, air filter. I checked the safety fuel valve solenoid and it works. Got it all back together, and yet again, no fuel. Having the fuel line disconnected from filter, I expected fuel to squirt out while cranking, but nothing. When weather allows me, I will check the voltage and run a fuel line from gas can to the inlet side on pump and see what that does. I hope I don't have to drop the fuel tank and replace the line to the pump. I will update when I get it done.
38,773 PostsLatest Activity: Apr 24, 2026
