Fleetwood_Coupl
Feb 21, 2015Explorer
Propane gas is heaver than air, so if there would be a leak it should not rise up to the area were the heater is but I understand the concern. Some folks have made a box to go over the water pump area out of insulation board. Not sure if that would help with very cold weather but you might be able to make it oversize and then stuff more fiberglass insulation in around it. Maybe some heat tape if you can get a short one.
38,763 PostsLatest Activity: Dec 05, 2025
