Atlee
Sep 09, 2020Explorer II
I have found my new to me 2018 Redhawk 22J to be OK. It's not top shelf good, like my 2014 F150 is, but it's not a continuous "white knuckle" affair as soon as I get up to my 60-63 cruising speed.
I still plan on getting my own front end alignment done, making sire the caster is +5.5 or better. I also plan on getting a Road Master reflex steering stabilizer. When I hit pot holes which is inevitable on most interstates, the front wheels do seem to flutter back and forth a little before settling back to a straight position.
pnichols wrote:
I'm a bit of an outlier, I guess.
Our E450 24ft Class C has handled just fine right from the time I drove it new off the dealer's lot. I've always attributed it to the chassis being well within it's specifications in carrying only the weight of a small Class C.
It's cab floor has never been overly warm, but it does have heat shields underneath between the cab flooring and the engine exhaust pipes coming from each side of the V10.
It used to ride rough in the rear, probably due to it's rear suspension having weight rated leaf springs and shocks well beyond what the loaded coach requires. I eliminated the rough ride in the rear by installing special rear shocks. I don't think of this issue as a "handling" problem, per se. Probably a stock Chevy 4500 chassis under a small Class C would also ride rough in the rear.
I'm 6'2" and can still get by OK in the cab driving and when leaving the driver's seat to go into the coach.
In other than with a Ford E450 or Chevy 4500 chassis, how's does one find a heavy duty chassis under a small Class C in the U.S.? IMHO, the other chassis types now being used for small Class C motorhomes in the U.S. can be too close to their design maximums under certain conditions when in motion.
