AllegroD
Nov 23, 2015Nomad
goufgators wrote:Canadian Rainbirds wrote:goufgators wrote:J-Rooster wrote:
It's time to change your water filter Larry, and that problem will be solved.
Thanks! Now if I can just figure out how to get that 'stuck' filter removed...!
Make sure the lever is all the way up. Then give the filter a good two handed twist. (Don't rip the housing off the wall though!)
GOT IT OFF !! Finally! Instruction manual said to turn it counter clockwise to remove. That's what I was trying to comply with. Happened to try it clockwise and it came right off with use of an oil filter wrench.
Great. Did the instructions refer to the coupler being turned counter clock wise. Just typing out loud. Sometimes instructions aren't written well. My wife is a tech writer and can tell ya some stories.
Have you put a new filter on? If you have a bypass (likely) you can flush it first then switch to filter. You might get some bit of black out on first use. Does the new filter say to run water through it or soak it first. That could get rid of (some) black water.
