wq93
Sep 07, 2018Explorer
Gdlow wrote:
Has anyone ever used a OBD ll dongle for hard to reach places that fits with the BT adaptor.
My plugin fits to tight to the dash to use the OBD without loosening the dash temporarily.
If so where did you get? Amazon?:@
The extension cables from Amazon work fine. I use a Range module (defeats the GM system that switches the V8 into V4 mode) with my Corvette Z06 and I bought an extension cable with inline on/off switch from Amazon two years ago.
The OBD-II connector wasn't designed for high duty cycle usage so if you are constantly plugging/unplugging a device you should also use an extension cable to save wear on the stock OBD-II port.
