Dale_Traveling
Jun 16, 2015Explorer II
My coach -
Dash radio power from the house batteries. Manual seats. All batteries will charge from either the engine alternator or the converter changer when plugged in or on generator power. Once the chassis battery level exceeds 13.2 the Battery Control Center (BCC)will close the cross connect (AUX Start solenoid) and allow the alternator power to charge the house bank. Works in reverse when 120VAC is available. If a disconnect switch is active the batteries that not in the circuit do not get charged, house, chassis or both. The BCC will open the cross connect if either bank drops below 12.8 VDC to prevent something from depleting both banks.
38,763 PostsLatest Activity: Dec 05, 2025
