majordad
6 years agoExplorer
Odometer error
My 2001 fleetwood DP odometer reads a lot more miles than I have actually travelled. Could this be due to a shorter tire installed by previous owner, and what can I do to correct it?
Tyler0215 wrote:
This post veered off topic quickly! If the speedometer was set to kilometers you would know. 60 mph is approxamatly 100 kph. Do you regularly drive at 100 or more on the highway?
Yes different size tires can make the speedo read differently. It also screws up the odometer. Do a ten mile test and you will know how much off the speedo is.
