Daveinet
Aug 12, 2014Explorer
et2 wrote:Probably more directly in response to another poster who discussed water causing a crack. In your case, it sounds like a poor location if its near the tires. Stuff needs to survive common road conditions. You did mention they claimed it was a maintenance item, which implies it is expected to crack regularly.Daveinet wrote:et2 wrote:NO IT IS A DESIGN PROBLEM If frozen water can crack the plastic bowl, then it is a really stupid design by incompetent engineers. In what grade does one learn that water expands when it freezes?dsteinman wrote:
Why is the water separator not under warranty?
David
It's a maintenance item. That's what I was told. Just like fuel filter and oil filters. $120.00 labor & parts.
I didn't say frozen water caused the crack, and neither did Cummins. The bowl is plastic. Maybe a stone or road debris caused the crack. It is located behind and up from the rear wheels. The water separator in my last Dodge PU was plastic as well. It never cracked.
38,766 PostsLatest Activity: Jan 10, 2026
