loneryder
Aug 15, 2015Explorer
Oil analysis of Ford V10 and Mobil 1
Thought you folks would want to see this oil analysis after a cross country thru the western mtn ranges. Mobil 1 EP 5-20 @5500 miles. Did the job but I wouldn't go over 7500miles on it. I consider this severe duty use.
LAB NUMBER: G95203 UNIT ID: RV
OIL
REPORT DATE: 8/14/2015 CLIENT ID: 71535
REPORT
CODE: 83/501 PAYMENT: Prepaid
(Typewriter comment blank)
TFord 6.8L 418 CID V-10MAKE/MODEL: OIL TYPE & GRADE: Mobil 1 5W/20 Extended Performanc
UNIGasoline (Unleaded)FUEL TYPE: OIL USE INTERVAL: 5,500 Miles
2014ADDITIONAL INFO:
COMMENTSSTEVE: Thanks for the notes about the towing and hard use through the mountains. Your V-10 handledthat well. For such a new engine, we honestly expected more residual wear-in metal since that can take awhile to wash out, but it's not here. Universal averages show typical wear levels for this type of engine afterabout 4,400 miles on the oil and this engine compares nicely. Silicon is probably harmless sealers washingout, but you can always check the air filtration system just to be safe. The TBN is 3.3 showing activeadditive left. Try 7,500 miles next and check back.
ELEMENTS
IN
PARTS
PER
MILLION
MI/HR on Oil 5,500
UNIVERSAL
AVERAGES
MI/HR on Unit 7,500 UNIT /
Sample Date 8/5/2015 AVERAGES
LOCATION
Make Up Oil Added 0 qts
ALUMINUM 6 6 5CHROMIUM 1 1 1IRON 32 32 19COPPER 5 5 5LEAD 0 0 1TIN 0 0 1MOLYBDENUM 77 77 65NICKEL 1 1 1MANGANESE 2 2 1SILVER 0 0 0TITANIUM 0 0 0POTASSIUM 6 6 2BORON 44 44 51SILICON 51 51 19SODIUM 13 13 41CALCIUM 1211 1211 2127MAGNESIUM 712 712 210PHOSPHORUS 672 672 743ZINC 827 827 903BARIUM 0 0 1
Values
Should Be*
PROPERTIES
SUS Viscosity @ 210°F 51.4 46-59
cSt Viscosity @ 100°C 7.69 6.0-10.2
Flashpoint in °F 410 >355
Fuel % <0.5 <2.0
Antifreeze % 0.0 0.0
Water % 0.0 <0.1
Insolubles % 0.1 <0.6
TBN 3.3 >1.0
TAN
ISO Code
* THIS COLUMN APPLIES ONLY TO THE CURRENT SAMPLE
416 E. PETTIT AVE. FORT WAYNE, IN 46806 (260) 744-2380 www.blackstone-labs.com
©COPYRIGHT BLACKSTONE LABORATORIES 2015 LIABILITY LIMITED TO COST OF ANALYSIS
The 3rd number of each element is what it should be after 4400 miles.
OIL
REPORT
ELEMENTS
IN
PARTS
PER
MILLION
MI/HR on Oil 5,500
UNIVERSAL
AVERAGES
LOCATION
Values
Should Be*
PROPERTIES
Fuel % <0.5 <2.0
Water % 0.0 <0.1
TBN 3.3 >1.0
TAN
ISO Code
