bill257
Oct 08, 2017Explorer
Oil and filter change
How many of you do oil/filter change yourself on your RV.I have done it on my car but not RV.Is it difficult.Mine is coachman Freelander 32BH.It has Ford engine i believe 450 super duty.
bill257 wrote:
Ok will do it myself. A question do I need to use oil filter wrench to loose and then tighten the filter or just hand tight.
ScottG wrote:
Yes, I use one hand to loosen but would use the other as well if it weren't holding up the truck.
ksg5000 wrote:X-2, don't even need to jack it up or use ramps, you will need a wrench to loosen, but tighten by hand.
More clearance under the RV than the car - pretty simple job.
