CharlesinGA
Jun 19, 2017Explorer
There is a dipstick tube with a cap, but no dipstick, you have to buy that. It should not be left in the transmission, it is considered a tool, buy a good one, not one of the cheapie ones which come apart.
http://www.autohausaz.com/search/product.aspx?sid=yymlos55yjui4iq4elke30j1&makeid=800016@Mercedes&modelid=1363867@E320&year=2000&cid=33@Transmission/Transaxle&gid=10027@Auto%20Trans%20Dipstick
There is a lot of knowledge and care that is needed for MB maintenance if you want to do it right. Use only the approved spec oils and for certain the proper transmission fluid. Spec has changed since '08 and the most readily available fluids are Shell ATF134, Fuchs 4134, the genuine MB fluid, and Mopar Sprinter/Crossfire fluid. All of it is hard to find and expensive. DO NOT use an unapproved fluid in the transmission unless you want a new tranny.
I highly suggest you join the View/Navion forums on Yahoo, there are three, all separate forums, managed together, one is the general forum, one is the techie forum, and the last is the modifications forum.
https://groups.yahoo.com/neo/groups/View-Navion/info
https://groups.yahoo.com/neo/groups/View-NavionTech/info
https://groups.yahoo.com/neo/groups/ViewNavionMods/info
Charles
2007 Winnebago View 523H on a 2006 Dodge (Daimler-Chrysler aka Mercedes) Sprinter 3500 chassis (T1N). Bought Sept 2015 with 18K miles on it, Prog Ind HW30C, Prog Dymanics PD4645, Coleman Chill Grille, PML/Yourcovers.com deep alum trans pan, AutoMeter 8558 trans temp gauge, Roadmaster sway bar, Koni Red shocks (front & rear), Fantastic Ultra Breeze hood, added OEM parabolic mirrors and RH aspherical mirror, MB grill conversion.
Charles
38,782 PostsLatest Activity: Sep 18, 2026
