WILDEBILL308
Mar 30, 2016Explorer II
Oil bath hub's
I had always thought my hubs were the grease packed type. Therefore I had not re packed them and haven't pulled the front wheel covers off. Well what do you know I have oil bath hubs. :P
Yesterday I drained the oil (they have the drain ports) and re filled with Royal Purple gear oil. There are a couple of things I noticed,
One is the drain plugs have magnets built in, so check for excessive metal shavings. It would be extremely easy to under fill the hub. When you add the new oil it takes a long time to flow back in the hub. It will look full but 5-10 minuets later it is below the line.
I was doing a couple other things like changing the oil on the generator so I kept checking the oil level and re filling. I can see how easy it would be to not get enough oil in the hubs. Say at a shop where they were in a hurry to get you out.
Well I am glad I pulled the wheel covers off to measure the bolt pattern as I was planning to convert to the oil bath style.
I don't know how much the hubs are suppose to hold or that I got all the old oil out (I didn't have anything to suck it out) I may do a repeat after a trip to Fredericksburg Texas next month.
Bill
Bill
