- IvylogExplorer IIIOnce out of warranty there is no good reasons to change once a year. 250 hours which could be 12K miles is a good number. I change mine every 15K miles which can be 2-3 years. You can have SpeedCo do an oil analysis before changing and even with 15K miles on it you will find it's still good to go even longer, especially if you change just the filter.
40 years ago with oil testing I went to 200 hours on my off road equipment... oils have come a long way in 40 years and driving down the road is a lot easier on a machine than off road. If you are close by and change once a year I'd be happy to dispose of your oil. - VoodooMedicineMExplorer
I agree - GHOST1750ExplorerI change my CAT 330 every December or January, that is when we begin our yearly schedule of trips and rallies . This time while servicing they found the Turbo was leaking. Tradewinds is still in the hospital and I'm going broke. :R
- ferndaleflyerExplorer IIII change it every spring
- Bill_SatelliteExplorer IIYou may believe that a $100 or so once a year is too much, but it's not for me. I change the oil once a year no matter what. I have an older engine where the parameters are 10,000 miles or once a year but your engine is likely 15,000-20,000 but still once a year. You can send in samples or any other test you like but if you change it once a year despite lesser mileage you cannot go wrong.
- prstlkExplorer10k or once per year. My manual says 15k or once per year. Cummins 330
- down_homeExplorer IIWell ours seems to get changed before it gets dirty about 2000 miles a year at most lately. I know in Az when we had the oil changed it was still yellow in the drain pan. He asked why change it. Well it's been a year..
Depending on oil capacity and cooling, one year certainly is safe.
Oil does break down. I had a quart of auto brand synthetic sitting in garage for Mother In Laws car. She quit driving in 2001. I said, well, I'll use it in the truck. It came out slowly and then a big thick lump.
est advice is what the engine mfg says to change it at and more often if very hot or very wet or cold or dry or sunny or dark. - Bruce_BrownModerator
dons2346 wrote:
dave_330 wrote:
How often should you do an oil change on a diesel engine?
Follow what your engine manual says
Exactly. Not all are the same. Our ISL is 20,000 miles, our old Cat was 10,000 miles.
Due to time vs miles, I change ours at 10,000, which is overkill by any account.
38,705 PostsLatest Activity: Jan 20, 2025
