Rwake901ExplorerAug 25, 2017Oil Filled space heaterDoes anyone use those oil filled radiator space heaters in their RV and if so do you feel safe using them at night while sleeping? I'm thinking about buying one. Thanks
MrWizardModeratorAug 25, 2017They work fineIf you want it on 24/7 run the external cordOr you can think of it just like the A/C , if on 30 amp power, turn it off when using the MW or hair dryer etc..Power Management is the keyMost are only 1200w and use less power than the A/C , also no power factor to va loss, like there is with A/C compressors
Related ContentSpace HeaterElectric space heatersSpace heater recommendations?Gravity fill portSmall space heater
