Does anyone use those oil filled radiator space heaters in their RV and if so do you feel safe using them at night while sleeping? I'm thinking about buying one. Thanks
You got exactly the same amount of heat you would have had from a 1500 watt heater that cost $9.99. Just that the 9 buck unit is not quite as pretty to look at and takes up a bunch less space.
Be careful when doing all electric heat. The water systems may require the furnce to run at least some of the time. There are ways around that.
