egh33ExplorerMar 25, 2014Oil Hubs ( front)Does any one know what the maximum oil level for the front hubs?? It has a mark for minimum, but no line for maximum. There is a oil stain on the outside of the hub, not fresh, looks like it's been th...Show More
wa8yxmExplorer IIIMar 28, 2014I would type a bunch more but...rgatijnet1 did it right posted the manual pageAny level between the "Minimum level" circle and the bottom of the rubber plug, or rather the bottom of the hole it plugs, is proper.I prefer to fill via the drain plug (the one you can rotate to the top) cause it is easier to do that way.
Related Content4x4 front hubOil filled front hubsoil filled hubs/front wheelsWheel hub oilWheel Hub oil!!
