Ed_ManifoldExplorerJan 28, 2014Oil leakI have a small oil drip at the left rear corner under the radiator area . The drip looks like auto trans oil and all I can see when I look under is where the leak has run down on what I think is the l...Show More
wolfe10ExplorerJan 28, 2014The other "radiator" is the CAC (Charge Air Cooler), also called After-cooler, also called Inter-cooler.It is in front of (front of coach) the radiator.It needs to be cleaned from the FRONT, which is where the dirt collects.
Related Contentoil leakoil leakOil change service??? Mercedes-Benz sprinter.Oil filter leakingLippert faucet leaks, replaced with Moen
