rgatijnet1
Sep 26, 2018Explorer III
Unfortunately a single oil analysis is not that informative unless it has a history of other test results to go with it. What you are looking for is a CHANGE from previous tests.
There are other tests that you can do such as a cylinder leak down test which may be able to tell you more about piston wear as well as the valve condition.
38,782 PostsLatest Activity: Aug 31, 2026
