carringb
Sep 26, 2018Explorer
I'd suspect maybe a poorly seated air filter, but nothing to be worried about.
The v10's air filter is easy to install slightly out of alignment allowing some air to bypass. Also, some aftermarket filters have better gaskets than others. If you pull you air filter and there's is a chalky film behind it, your filter isn't fully seated. If this is the case you might improve driveability by cleaning your MAF Sensor.
38,782 PostsLatest Activity: Aug 31, 2026
